How do I replace the charger conection on the phone?
The charger connection on the phone has gone bad and won't charge. Is this something that can be replace?
Questa è una buona domanda?
It will have to be soldered on. I do this everyday but if you are a novice this may a little to difficult. It requires special soldering skills to do. You can easily overheat the circuit board or pull a solder pad up. I would look for a good local cellphone repair shop. Should be about 60 dollars to replace. Good luck.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 206
