Salta al contenuto principale
The Lexus ES is a series of compact, then mid-size, and later executive car sold by Lexus since 1989.
Location of cylinder 6 on the Lexus ES300 engine?
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi. I found this answer on wiki.answers.com, so I'm not entirely sure if it's correct. I'm sure the community will correct me if I happen to be wrong. "The number 6 cylinder is located on the drivers side front toward headlights, here is the entire order: pass side back by firewall = 1, center=3,drivers side back=5 and the front cylinders are: pass side front=2, center=4, drivers side front=6"
Punteggio 5
I replaced the coil on the #6 cylinder which was having an error, and can confirm that the #6 position is correct
Punteggio 2
Aggiungi la tua risposta
Walter Tyz sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 76
Tutti i Tempi: 23,364
