My phone wont charge anymore
The charger port from my phone broke and when I connect the charger it wont charge,help!
Questa è una buona domanda?
Sandy, replace the charging port. It is soldered onto the logic board and is a bit of a PITA to solder. Check this teardown and see if this is something you would like to tackle. Hope this helps, good luck.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 313
Did you tried another usb cable?
Did you tried another computer of usb current source?
If all answer is yes, maybe the USB port is getting bad joints on circuit soldering. Need to change the USB connector board, or another logic board.
da Stephane Robert
