Salta al contenuto principale
This Apple Cinema Display is characterized by the M8149 model number and was first released in July 2000
7 Domande Visualizza tutte
top half of screen dark
Dear all,
Can anyone give advice on how to fix the following? I have a Apple Cinema Display M8149 connected with and ADC-DVI adapter to a Mac Pro or MacBook Pro. Some time in the past the top half of the screen suddenly turned low in luminosity, right trough the middle of the screen. It still show an images but darker than the bottom half. So the top-half has half the luminosity of the bottom half. Feels like some fuse issue? Or maybe something else? Can anyone identify this problem and advice how to fix it? I ruled out the adapter (same problem with a new one) and the graphics card (same problem with different computer setup ). All help is appreciated!
Kind regards,
Marcel
Questa è una buona domanda?
Punteggio -1
1 Commento
Be careful with what you spend on parts as this thing can be bought for under $80 now.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Marcel, sounds like either a bad inverter board or a burned out CCFL. I'd start with the inverter board since it is easier to replace than a CCFL.
Punteggio 1
Aggiungi la tua risposta
Marcel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 684
