Salta al contenuto principale
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 Domande Visualizza tutte
which power/volume control cable do I need?
Is the CDMA version of the power/volume control cable the right replacement? beacuse the one for the old ipad 2 model is to long, the only one that looks the same is the coma version, should it work here? thank you :)
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
New iPad 2 wifi use a special cable, for this device only. Cables from other models are not compatible
Punteggio 0
Aggiungi la tua risposta
Martin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 278
