Salta al contenuto principale
La Time Capsule modello A1302 è la seconda generazione di router wireless e dispositivo di archiviazione in rete di Apple, rilasciata a marzo 2009. Gran parte delle informazioni presenti in queste guide di riparazione e smontaggio si applica anche al modello A1254 originale.
time capsule dead, hard drive possibilities?
My time capsule will not work, I have tried everything. What I want to know, can it be wired just to be an external hard drive? Can I place an OS on it and use it for storage? Reformat? Basically I have pulled it out of the case and want to know has anyone rewired the connections to have it work, it seems a waste to have a TB hard drive and having it sit static.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
3 Risposte
Soluzione prescelta
Which hard drive do you have and does it have standard SATA connections?
The hard drive typically found in a Time Capsule is the Hitachi Deskstar, which is sold by Hitachi as a consumer-grade product—the Hitachi Ultrastar is the enterprise version.[13] Apple labeled the drive as a server-grade drive in promotional material for Time Capsule, and also used this type of drive in its discontinued Xserve servers. Apple states that the Hitachi Deskstar meets or exceeds the 1 million hour mean time between failures (MTBF) recommendation for server-grade hard drives.[14]
The 500 GB, first generation Time Capsule shipped with a Seagate Barracuda ES-series drive.[15] More recently, other hard drives such as the Western Digital Caviar Green series,[16] and the Samsung EcoGreen series have been reported.
Punteggio 1
If your question was can I connect this HD to my Mac system directly via the universal SATA adapter.
The answer is no, this HD uses a different format. So you can't recover any data from it nor can you prep the HD via your Mac. The AirPort Utility has the needed functions to prep a new HD if you swap it out.
Punteggio 0
To further the discussion: My first generation Time Capsule power supply failed, and I bought a new TC. I have removed the old Seagate Barracuda ES hard drive and want to get a power supply so I can retrieve data on it. Can I buy an external power supply of some kind?
Thanks,
Phil
Punteggio 0
Aggiungi la tua risposta
Paul Hicks sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 19
Tutti i Tempi: 3,274
