Salta al contenuto principale
The Samsung Galaxy S 4G is an Android 2.2-powered smartphone with a 4-inch AMOLED touchscreen display and 1 GHz processor.
62 Domande Visualizza tutte
front glass broken repair. Risk?
My new's galaxy s4 front glass was broken. I watched the video for repairing it with the hair dryer.
Is it a big risk destroying the lcd with that procedure or if you are really carefull and delicate you have sure results?
Questa è una buona domanda?
Punteggio -1
2 Commenti
is it just the front glass?
da
yes just the front glass.Screen functions.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
this is one guide to replace your screen
Punteggio 1
Risposta Più Utile
you need a really hot hair dryer temp to do this is around 150 to 200 degrees (any higher and you will damage the LCD) its a slow process but if you have the patience its worth it then paying the huge cost of a new display. key pointers is go really slow like snail slow and make sure the screen stays hot. before you begin remove the battery and Logic board cause you may damage them. gloves and a laser thermometer help.
Punteggio 2
Aggiungi la tua risposta
Nikola Pap sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,055
