Salta al contenuto principale
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 Domande Visualizza tutte
Replacement Power Supply Options
So I am pretty sure the iMac im working on has a faulty power supply. The original 240W power supply shows a trickle charge (1 led) when installed, and when you try to power on the computer LED's 2 and 3 flash quickly (less than 1 second) then all 3 go out. I purchased a replacement PS 614-0432 which has all the same connectors, but is rated at 250W. After installing it I believe the replacement is defective anyhow (2nd hand part) as I don't even see a trickle charge LED.
After doing some looking I see it's next to impossible to find an original 240W power supply (614-0405). I see lots of people recommend the 661-4478 power supply which is also rated at 250W. I was wondering if anyone has replaced the original power supply with a newer higher wattage PS without any issues, I'd really like this to work on the second shot. Any insight anyone would have would be great! Thanks!
Questa è una buona domanda?
Punteggio 1
1 Commento
Did you ever find the solution? as I have the exact same issue
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Seems legit - but there's a tech note you need to have/use the new power wall too.
If this Answer is helpful please remember to return and mark it Accepted.
Punteggio 2
Aggiungi la tua risposta
Bob Mintern sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,063
