cleaniang rust from logic board
Anyone ever use corrosion x to clean rust from logic board?
Questa è una buona domanda?
To start with there is very little steel or iron present in your system. So using any Rust Remover across your logic board would not be the best solution and could in fact harm your system!
I stay away from spray cleaners or contact cleaners as they tend to leave an oily film which can cause odd behavior and collect dust over time.
The best solution to clean any corrosion caused by getting your system wet with water or a drink of some sort is distilled water and 85% or better isopropyl alcohol.
But before you start your endeavor you must disconnect the battery as soon as possible! As the power you battery has stored in it can cause electrolysis and depending on what was in the liquid cause sorts damaging the components.
So here's the timeline of actions:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 887
