Salta al contenuto principale
External storage options by Seagate, usually connected by USB, available in many storage sizes and form factors.
Why is it not detected?
When I plug in the computer USB port the drive is not detected; the green led blinks and I can hear weak continuous beeps. It is a Seagate 750GB external hard drive.
Questa è una buona domanda?
Punteggio 3
1 Commento:
I have a Seagate 1.4TB external drive with a dedicated power cord; and mine also isn't being detected. Tried it unsuccessfully on 4 machines: Windows XP, Linux Ubuntu, an Apple Mac and a Toshiba Android tablet. No go. It makes whirring sounds for a few seconds then quits.
da
Aggiungi un commento
2 Risposte
Assuming the drive is ok (have you tested it on another computer) it might be, that it demands too much current from the USB port - had this with an older FSC drive (I think with a Seagate or WD drive builtin).
Regards, Stone
Punteggio 0
External HD is composed by two parts: a controller and a classic HD. I would try to open it and conect the HD directly to the mainboard with the right interface (sata or parallel) ... if it works by anothe case/controller (very cheap) if it's not recognised ... it's above my knowledge ....
Punteggio 0
Aggiungi la tua risposta
ratish sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 731
