Dark stripes in the bottom right corner
Hello,
I have weird dark stripes in the bottom right corner of the screen.
Please see the picture.
The don't go away, the persist from the time display lights up. I have also tried different instructions on the similar question (involving Ctrl-Option-Eject) with no positive results.
I'd be grateful for a help in diagnosing the problem and in finding the cheapest way to fix it.
Thanks in advance!
Questa è una buona domanda?
4 Commenti
looks like your backlight is failing. What you are seeing are the backlight LEDs shining (looks like only half). This could be the backlight itself or the WLED driver on your logic board. there is really no an easy or cheap fix for this.
da oldturkey03
Sorry to say I agree with OT here the LCD assembly will need to be replaced.
da Dan
oldturkey03, thanks for your answer. Is there a way to test whether the problem is in the display part (which can be fixed by replacing the whole display unit) or in the logic board (which would require replacing with the new logic board as I understand)?
da Igor Saprykin
Yes, a replacement should fix it. It will determine if it is your LCD (most likely) or your WLED (less likely) If you have a different display, use it to find out. you know where to find the best guides for the job, MacBook Pro 15" Unibody Mid 2010 Best of luck to you.
da oldturkey03
