Salta al contenuto principale
The Nokia Lumia 920, developed by Nokia and released in November 2012, utilizes Windows Phone 8 operating system.
56 Domande Visualizza tutte
The phone is not turning on.
I had left the phone out in my truck in the Arizona heat for a whole day now it doesn't turn on or charge, and when its on the charger it doesn't turn on either. It shows that it"s charging but that's it. How can I fix this problem?
Questa è una buona domanda?
Punteggio -1
1 Commento
I got the same problem today!:/
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
is you vary well know Arizona can get really hot and for the cause of that people in hot climates can have trouble with any kind of battery. heat kills battery's. your phone for sure is still working but the battery is internally damaged. the average max temp for it to charge is 113°F until it wont charge at all and 140°F is the max until it starts to fail from working.
*This average can vary*
You said you left it in your truck all day which can turn your truck into a oven reaching around 180°F, Your going to have to tear down your phone and replace the battery and if i were you i would keep a spare just in case.
Punteggio 0
Aggiungi la tua risposta
Jeremy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 876
