power button does not work after replacement
I have replaced my power button because it did not work and now it depresses and clicks but still does not activate. I have gone back through the steps again and it still does not work. I am beginning to wonder if i damaged the power and sensor cable when it put it in?
Questa è una buona domanda?
6 Commenti
are you talking about the home button? or lock button? I am having the same problem with my home button... ive tried a bunch of time to reinsert the little prongs but i dont know if i damaged something, if you got yours to work, help me out
Thanks!!
da Rachel
Hello!
Did you replace the lock button flex cable? Or did you just replace the metal button that you press?
da Josh Wright
I replaced the flex cable under the power button. The power button now depresses properly but does not carry out the actual turning on or of the phone.
I think i damaged the new one when i installed it in the phone. I will try again when my replacement arrives.
da Nathan Turney
Does the phone still function and turn on? It could be that the phone is non-functional anyway. And okay get back to us with the results :)
da Josh Wright
The phone works fine! All apart from the power switch:-( I will try to repair it again and if it doesn't work then so be it:-)
Thanks for your help:-)
da Nathan Turney
Mostra 1 altro commento
