Salta al contenuto principale
Lanciato nel giugno 2009 / processore Core 2 Duo da 2,53 GHz
170 Domande Visualizza tutte
Swapping Entire Internals from Matte to Glossy MacBook Chassis
Hello everyone,
Thank you for taking the time to read this.
I own two Macbook Pro 2009 Model A1286's.
Computer A is a Matte Screen version
Computer B is a Glossy Screen Version
Computer A has display issues (2inch vertical band of multicoloured lines just to the right of the sight camera) as well as a battery that doesn't hold charge very well.
Computer B suffered liquid damage on the logic board and does not power up.
Computer A (matte screen) is very well used and the housing is scratched/dented/dirty etc.
Computer B (gloss screen) is in almost pristine condition, it is only the internals that are damaged.
What I would like to do is swap the entire internals of computer A into the chassis of computer B.
Should I face any issues doing this? Is it as simple as simply swapping the logic board and hard drive from computer A into computer B?
I appreciate anyone taking the time to answer this.
Thank you.
Janaka
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If you feel your up to doing it, two exact systems should be no problem in swapping things out.
Take your time and make sure you have a few egg crates to hold the screws and small pieces and the proper tools.
The only thing I can think of is the water damage system may have a few corroded screws.
Also, don't forget to use proper ESD protection as you'll have the logic boards exposed.
Punteggio 0
Aggiungi la tua risposta
Janaka Rodrigue sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 168
