Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
iPhone 5 point screw stuck
after screen replacement i saw, that on/off button doesnt work properly. It work if only i push on the left side of it. I decided to open iphone again, but i cant do it because one of 5 point screws stuck. It rotates easy in both directions, but i cant let him out. Do you have any ideas how i can get this screw?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
if they rotate but don't go out, mabe could you stick them and then pull. I guess (but am mabe wrong) that you used another screwdriver than the right one. You may order new screws and replace it, using the right one. This kit enables you to replace the current with philips screws [prodotto collegato mancante o disabilitato: IF118-023]
You may also screw in your power button harder. There are two screws that can easily go away while using your phone.
Hoping to have helped you !
Vincent
Punteggio 1
2 Commenti:
thanks, vincent. I used proper screwdriver, and i think it happened because i rotated the screw with angle, i mean not exactly in the hole.
The problem solved now (i used suction cup to create tension, so screw started to come out).
Can you explain what screws i need to screw to fix power button?
i saw the manual, but its not all clear to me.
da
Glad to read that you succeded ! There is in fact only one screw (2 on the iPhone 4) shown on the step 29 of this guide : Sostituzione controllo audio e cavo pulsante accensione dell'iPhone 5 you may have to use à #00 Philips screwdriver. Keep me informed
da
Aggiungi la tua risposta
oles sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,369
