Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Why is it rebooting constantly after replacing Power/Volume flex?
I replaced the Power/Volume flex cable in an iPhone 5 and it is now constantly rebooting. Everything seems to be functional as normal apart from this rebooting issue. I was informed that the phone did not do this prior to the cable replacement. Could it be a bad component or is there something else that could be causing this?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
The 1st thing you may do would be reopening it and checking that your battery is well connected, and all the connector pins absolutely clean.
Hoping to have helped you,
Vincent
Punteggio 1
I am having the same problem. I replaced the power button cable and starting getting the random reboot and battery percentage problem. Looked at the diagnostic page on the phone and has a kernel panic showing a CRC error. Anyone have any thoughts on what the problem could be?
Punteggio 0
Aggiungi la tua risposta
JonMark sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 356
