Salta al contenuto principale
Modello A1136 con 30, 60, o 80 GB di hard disk con plastica frontale bianca o nera
798 Domande Visualizza tutte
iPod stuck on hold
After replacing the battery in my ipod 5th generation 60gb my ipod was not coming off hold. I bought a replacement hold switch on eBay and after replacing this the ipod is still stuck on hold. Could this be the logic board?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hugo, the way I would proceed is by checking the flex first. Make sure it is properly seated and locked. Then check the switch on the flex itself, check to make sure that the switch is properly engaged between the two tabs of the slider. You can recheck this by keeping your iPod open while you try it out. If that still wont work, I would definitely try one more flex cable before replacing anything else. Hugo, if you place the iPod on Hold, and then disconnect the flex cable, the iPod will remain on Hold. Hope this helps, good luck.
Punteggio 1
1 Commento:
Hi,
I tried another hold switch cable, but no luck. So I guess I will go to replacing the logic board with I guess will solve any problems.
Thanks!
da
Check the wires that connect the hold switch to the logic board. If nothings wrong with the wires check the pins on the logic board. If this fails replace the logic board.
Punteggio 0
1 Commento:
Thanks Jacob, on the pins should I just look to see if they are misaligned at all?
What is strange is when I disconnect the hold switch wire from the logic board the iPod still remains on hold? Its a real shame if it is the logic board as apart from this the ipod was functioning well.
da
Aggiungi la tua risposta
Hugo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 192
