Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
How do I fix the lock button on my iPhone 4
I have taken a look at the lock button and the actual mechanism seems to be fine because it clicks perfectly when I push it with my finger. If I buy a new lock button is this guarnteed to fix the problem? Also should I buy just a new button or a whole new mechanism and button? Thank you
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If you dismassembled your iPhone yourself, the warantee may not work. Even if you can manually click on the sensor cable, it can and is certainly used and Will no longer work with the button. You Will find a new power sensor cable @ ifixit store for $15 and easily replace it by following their step-by-step replacement guide. I had the same problem :)
Hope I have helped you !
Vincent
iPhone 4 Power and Sensor Cable (GSM/AT&T)
Punteggio 1
Aggiungi la tua risposta
Harry Bouch sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,175
