Salta al contenuto principale
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Replace iPad mini flash memory
Its is possible to change de IPad mini GSM 16 Gb Flash memory by 64 GB?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
5 Risposte
Soluzione Prescelta
As you seem to know, iPads memory is flash memory. Removing it would be like trying to remove black parts on a RAM bar. This would be destructive for your device.
Hope I helped you !
Punteggio 3
Review the iPad mini teardown as you can see the flash storage is soldered down look at Step 21.
Between getting the correct flash chip, the needed skills to do this, and the amount of work it would require it really doesn't make sense given the price of buying a new unit.
Punteggio 3
possible but very destructive. It is very difficult to reassemble any ipads back to factory quality
Punteggio 2
CAN i REPLACE THE FLASH MEMORY IN A IPAD MINI WITH A NEW BLANK ONE? I mean does it have to be loaded with any kind of firmware for the ipad to function normally?
Punteggio 0
2 Commenti:
No not possible as stated by everyone this would not be possible or cheaper than just buying a new unit.
da
That wasn't his question. Yes it would need some sort of firmware to allow it to obtain some sort of iOS install. There is a video on youtube who upgraded and iPhone storage (arguably harder than the iPad repair) by soldering a new flash storage chip on. If you have nothing to lose and feel like giving it a shot then i say go for it. But the better method would be to just change the motherboard entirely
da
No, not at all, you would have to get your hands on some iOS. Which you can’t, at least me and you cannot.
Update (10/01/2019)
But there is a video on YouTube that can help you
Punteggio 0
1 Commento:
Is it impracticale yes....can it be done also yes
da
Aggiungi la tua risposta
jose maria marques alamo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 22,191
