Salta al contenuto principale
The Motorola Droid 4 is a smartphone made by Motorola that was released with Android 2.3 and is upgradeable to Android 4.1.
25 Domande Visualizza tutte
Touch screen unresponsive when keyboard is slided out
So that is my problem, when I slide out keyboard, touch screen or buttons under it (home, back, etc). Become unresponsive, screen works great no distortions of any way in screen and as soon as I slide keyboard back in it becomes responsive with any issues.
Could it be that some kind of flat/flex cable needs replacement?
Also... if for example I click on icon and then slide keyboard in. It will react on the click. Like keyboard is blocking the the touch input.
Another thing, I was tinkering with input settings and once I made them work both, but when I rebooted phone I'm stuck with the same problem.
UPDATE: I just did a factory reset, problem persists so it might have been coincidence that it started working after my tinkering.
So... please advise me on both software and hardware solutions for this problem.
It uses Android 4.1.2, not rooted, but thinking of doing it.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Very strange. My only idea would be to replace the flex but i have to admit i haven't seen anything like that in a long while. good luck
Punteggio 1
2 Commenti:
Could this be the part in question?
http://www.etradesupply.com/motorola-dro...
It's the only part I found that could be it.
Thank you!
da
Yup! If the flex is the problem then that would be your part! Just be careful. pretty hard repair and if its the same phone im thinking of, things get pretty hairy once into the top portion of the phone. Good luck friend!
da
Aggiungi la tua risposta
alexxandar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,079
