Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Very broken iPhone 5. Any hope?
Hi.
There was someone who asked me if I could look at there broken iPhone. To see if there is any hope for it :p
It looks like this:
And it have several torn off flex cables (all at the top :p)
The phone works fine after all, but my question is if this cable (attached where the picture shows, and on the logic board) can be replaced or fixed? :
What is that cable for anyway? :p
Questa è una buona domanda?
Punteggio -1
1 Commento
where does it the cable go exactly as in what general area?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
alex, it looks like the "cellular Interconnection Flex, cable that broke. You can get it from places like this as well as from here. Of course, depending on some more images to absolutely verify this. Hope this helps, good luck.
Punteggio 1
2 Commenti:
Thanks oldturkey03. Thats the clable that broke.
Maybe you know if I need to solder it back on?
da
alex, yes you do.
da
Alex,
It looks like it possibly goes to the camera and the flash, and maybe to the vibrating motors.
maybe the link here.
iPhone 5 Front Camera and Sensor Cable
24.95 + SH + Tax
and or the power audio cable.
iPhone 5 Audio Control and Power Button Cable
24.95 + SH + Tax
I had a friend that threw his and it hit the ground kinda looked like the one in the picture.
I had to replace both not bad to fix be careful.
I hope it is that easy for you.
Regards,
lajjr
Immagine iPhone 5 Front Camera and Sensor Cable
Prodotto
Immagine iPhone 5 Audio Control and Power Button Cable
Prodotto
Punteggio 0
1 Commento:
Thanks for your answer :) but it's not those cables :p those are torn too but the one i'm asking for is attached under the logic board (upper left corner). And attached to the housing with two screws..
da
Aggiungi la tua risposta
alex sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 532
