kelvin stephenson, according to the service manual the Apple part number for the inverter is 922-8280. Here is the compatibility list for that number.
MacBook 13.3" 1.83GHz Core 2 Duo (A1181) - Late 2006
MacBook 13.3" 1.83GHz Core Duo (A1181) - Mid 2006
MacBook 13.3" 2.0GHz Core 2 Duo (A1181) - Early 2009
MacBook 13.3" 2.0GHz Core 2 Duo (A1181) - Late 2006
MacBook 13.3" 2.0GHz Core 2 Duo (A1181) - Late 2007
MacBook 13.3" 2.0GHz Core 2 Duo (A1181) - Mid 2007
MacBook 13.3" 2.0GHz Core Duo (A1181) - Mid 2006
MacBook 13.3" 2.13GHz Core 2 Duo (A1181) - Early 2009
MacBook 13.3" 2.16GHz Core 2 Duo (A1181) - Mid 2007
MacBook 13.3" 2.1GHz Core 2 Duo (A1181) - Early 2008
MacBook 13.3" 2.2GHz Core 2 Duo (A1181) - Late 2007
MacBook 13.3" 2.4GHz Core 2 Duo (A1181) - Early 2008
MacBook 13.3" 2.4GHz Core 2 Duo (A1278) - Late 2008
information is from here.
The inverter cable part number for both models, numbers provided by you, is 922-8281. The cable is compatible with the following models:
MacBook 13.3" 2.1GHz Core 2 Duo (A1181) - Late 2008
same source as above. There are two types of connectors on the inverter cable. The earlier models used the 4-wall connector with a typical socket type end and the later models used the 3-wall connector that snap in. Hope this helps, good luck.
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
6 Commenti
Can you supply both systems last four digits of their serial numbers so we can correctly ID what you have. Make sure to denote which is the one you're trying to repair.
da Dan
Here's a breakdown on what is different by the specs between these two models: EveryMac
da Dan
Spares with block connector S/N: V0P1 - MacBook "Core 2 Duo" 2.4 13" (White-08)
To be repaired with flat connector S/N: R4R3 - MacBook "Core 2 Duo" 2.0 13" (White-09)
da kelvin stephenson
I don't find this part number 311OT-0174A in my Apple docs is this the manufactures part number for the display its self or Apples P/N?
da Dan
The number is most likely a 3110T-0174A and the display could be a LG/Phillips. There should be more numbers on the display.
da oldturkey03
Mostra 1 altro commento
