Salta al contenuto principale
Eighth generation of the Mazda Protege.
Where exactly is the Flasher Relay for a 2003 Mazda Protege located?
Questa è una buona domanda?
Punteggio 2
1 Commento
Thanks oldturkey03! I will check this out immediately.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Berry, the Turn signal/Flasher relay is under dash on drivers side. If you have a manual transmission is is almost directly above the clutch pedal. It is a gray colored box about 2 inches wide by 4 inches long. It is #5 in the attached diagram.
Hope this helps, good luck.
Punteggio 5
1 Commento:
Thank You very much , it solved my problem.
Thanks
Ronald (Philippines}
da
Aggiungi la tua risposta
Berry sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 51
Tutti i Tempi: 11,662
