Salta al contenuto principale
Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
Mini usb spoiled due to poorly plugging
Well, i lend my friend the controller.
and he not taking care of it and spoiled the mini usb.
it cant be charged but all buttons remain can be use
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
ng kai wei, follow this guide to remove the logic board. Then unsolder the USB port and replace it. Once you have it out, you may have to try places like mouser.com or digikey.com to find a replacement.
Punteggio 1
3 Commenti:
i see no guide on your comment, and im from malaysia, can i have the spec of the usb so i can find it local at malaysia? thanks
da
sorry about that here it is Sostituzione scheda madre DualShock 3 as for the dimensions, it might work if you measure it right of the board
da
thanks for the guide, but recently i bought a new mini usb. when i want solder it, i see the usb and the usb i bought is a different stuff. well thats was awkward..
da
ng kai wei, where did you buy the new mini usb in malaysia? i want one as well
Punteggio 0
Aggiungi la tua risposta
ng kai wei sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 367
