Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
How to Unblacklist My Device?
I purchased an Iphone 4 from gamestop and tried to get a quick prepaid service on it , and was denied because the phone was blacklisted. And being dumb I threw out the receipt smh ....Is there anything I can possibly do to unblacklist it ???
Questa è una buona domanda?
Punteggio 5
Aggiungi un commento
5 Risposte
Soluzione Prescelta
First check it here for black listing: http://www.imei.info/iPhoneBlacklistChec...
If it is indeed blacklisted, take the report to Gamestop (they should have a copy of your receipt) and demand your money back or a replacement iPhone. You did use a credit card to buy it, right? You can also report it to the police but if you are still in possession of it, you will probably have to give it to the police as stolen merchandise.
Punteggio 2
You could contact your service center or the network provider.
Imei Track
Punteggio 0
try imeiesnrepair.wix.com/imeiesnrpair I repaired my iphone 4s ,not sure if they do 5 or 5s
Punteggio 0
1 Commento:
I used UnlockBoom service to unblacklist my iPhone. It worked fine for my verizon iPhone 4s.
da
yes I have the same problem
Punteggio 0
i have a iphone that i bought off a family member and it is blacklisted i need to be able to get a cheap fix on this please help
Punteggio 0
Aggiungi la tua risposta
Matt T sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 23,120
