Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
iPhone 4 motherboard is chipped on top and WIFI is grey.
Hi,
I was wondering if there is a way to repair the part of the motherboard on Iphone 4 that is responsible for the WIFI (and may be the bluetooth too).
There are two "pins" on the top side of the Iphone 4 motherboard, the right one is supposedly the one responsible for WIFI, i have an Iphone that is in perfect condition, but that part is broken.
Is it fixable?
Thanks.
Update
i found someone with a wifi problem on ifixit, he assumed it was because of missing screw holes. but he has the same broken "horn" on the motherboard. Here is the picture:
http://img15.imageshack.us/img15/5610/ip...
Questa è una buona domanda?
Punteggio 0
2 Commenti
If the wifi is greyed out I'm not sure if there is a permanent fix for this
da
how so?, is it something mysterious involving aliens?
there should be a fix for a problem as simple as this
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Mo Ne, take a look at your complete board. It does not appear as if there are any traces that are interrupted, but it is possible that the component SP1_RF is interrupted. It would help if you have a picture of both sides of your board. SP1_RF is SPRING-UPPER-ANT-N90 and directly involved in your WLAN/BLUETOOTH/FM RADIO circuit. You could try an run a jumper to the component as shown in the schematic. A broken multilayer logic board is never a simple fix. Hope this helps, good luck
Punteggio 1
1 Commento:
That made me optimistic, thank you! i hoped to get a technical answer like that. Unfortunately i am not really up to doing that kinda stuff because I only got up to disassembling and assembling, but I found a good repair shop, and the guy said something that sounded really close to what you were saying.
I will update when it's fixed (hopefully)
thanks again
da
Risposta Più Utile
Connect the top RF test connector to the top bezel bypasses the contact pad. But greyed out wifi always means dead or loose wifi chip. Bypassing alone would not help
Punteggio 2
2 Commenti:
Hi there
Could you explaine what do you mean by RF test connector and the bezel , am new to this technical terms , but I have the same problem. ( broken connector pad)
Please help
Thanks in advance
da
Hi, can you please explain how to do this, i broke tip, but it does detecgt wifi, but only if you stand near router. Thanks
da
Aggiungi la tua risposta
Mo Ne sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 5,864
