Not turning on. Charging battery and have volts across logicboard
2010 Macbook Pro unibody will not power on. I tried it with power button and power pads. But it will not turn on. Strangely enough it will charge the battery as the indicator will turn orange when battery is plugged it and also will show the battery bars grow.
Any help will be appreciated in order to make it running again. Thanks
Adnan
I have added few pictures. First one with red rectangle. This is the one that is burn. If this can be fixed please tell me i
will really appreciate that. Also, if i can hear back quickly, so that i can take my Ebay listing off and keep my Macbook pro for fixing. Really appreciate.
Thanks
Questa è una buona domanda?
7 Commenti
If you've had the top case off recheck the connector to the logic board.
da originalmachead
Did you drop or get the system wet at some point?
da Dan
Did not drop it and never got wet. I have checked the connectors. It is charging the battery and I was able to measure voltage across the logic board. Can a faulty video chip cause macbook pro not to turn on somehow or bad processor.
Thanks for your replies
da Adnan
Would you give us a history on the machine with any problems or repairs made. Thanks
da mayer
All right guys. Thanks for all your responses.
Today i took apart the machine and took the logic board out. Upon close observation, i found out that one of the Chip next to the LCD cable connector is burnt. So, i am not sure if that is fixable or not. I am well versed with soldering but, to do that i will need a bad logic board of same 2010 macbook pro and i am not sure if that is possible even. So, i guess i will stop my quest for fixing this laptop.
Thanks for all your comments
Regards
Adnan
da Adnan
Mostra altri 2 commenti
