Salta al contenuto principale
The PSP 3000 was released in the U.S. on the 15th of October 2008.
20 Domande Visualizza tutte
I cant see my files and games insatlled in my PSP
I am having PSP 3000, I charaged it through my laptop via Data Cable. After charging There were no games and data in my memory card, it displays that there is no data in the stick.
Whereas, if i plugin my PSP into my laptop, through the data cable, i can see all games in folder, and pictures which i have captured. means the data is there in UMD card, 1.8 GB is in used outof 8 GB. Data can be seen and its opening in Laptop only, But if i open games folder in PSP, then it says, The folder is empty... Please suggest what to do... I guess software is curropted, there is some virues in it.. can anybody please tell from where to download its software for free.. and how to install it...
Please email me : ahmer.mirza766@gmail.com
Thanks..
Questa è una buona domanda?
Punteggio 18
9 Commenti
Hey guys! Don't know if we have the same problem. First of all, I did created the folder and named it ISO and inside it, I created another folder and named it VIDEO. I transferred the games there in ISO folder. After I transferred the games in the ISO folder, turned my psp back on, opened memory stick on games, no games appeared. Please help.
da
hey need help i haves a psp e1004 street when i put games in iso floder but it not shownging i also put update at "psp>game" but it not working
3 days ago repat the same process it work but it not show me games
da
READ MY COMMENT OK? first of all your usb cable have a problem there. try using the cable higher that your pc or use a card reader.TAKE NOTE: your psp have no problem ok ?
da
i have a problem with my psp too.I already inserted my memory stick inside my psp.It can be read but when i tried to open it says there are no games.content can be downloaded or purchased from Playstation Store.After that i check the information about the memory stick and it says Unknown.Help me how to solve this problem.
da
It's really unusual that it happened with my PSP Go on the internal storage instead of the card because i don't have a memory card. It happened in 2015, 3 years of researching and no proof. On my Linux it does show all the games, though. Glad i finally got my NES and GB games back
da
Mostra altri 4 commenti
Aggiungi un commento
13 Risposte
Risposta Più Utile
Hi, if u have a bad or corrupted memory card try coping the files to ur computer and then format the card using the psp. Then try putting the files back and check if u can access them. Write back on what u did. Good luck.
Punteggio 2
2 Commenti:
I do it but is not instal
da
When I see in the folder ( when connected to PC) I need to know why
da
i had the same problem i fixed it by pluging my psp without the memory stick and once i saw psp mode i putted back the memory stick in the psp and baam all my folders are back
hope it will works for you
Punteggio 2
5 Commenti:
It worked for me, since my card reader was partly not usable (can't be read anymore) and I have been looking for an answer to this problem. Hope it works for others.
da
mine said "usb mode"
it didn't work on mine
da
i dont have a memory stick from the very start or probably never noticed when it was gone
da
It worked at me thanks!!
da
I bought a brand new psp 3000 after taking it to my home after connecting it to the Internet I found that it can't open many websites such as YouTube, Facebook and many more.
I inserted a memory card of 8 GB and whenever I try to download any game it says not enough memory.
When I downloaded some files to fix this I opened games section but my files were not there.
What can I do now?
da
Connect your PSP to your PC and check if the PSP folder has the GAME folder in it. If it doesn't just make a GAME folder. And in that GAME folder create a new.txt notepad file and save it in there. Just put the games back in. And hopefully it will work.
It worked with mine, since there was a problem with the game Rockband Unplugged, but its fixed. Hope yours will be okay.
Punteggio 1
3 Commenti:
I tried and i have my game folder but there is nothing. Plz help me
da
what should i put inside that notepad ? i mean, what words should i type in there ?
da
Thank you so much this was so helpful I also had a problem with rockband unplugged
da
what you all don't know the secert the right method is here just open cfw then press when ever you see a x button in the screen the system wiil restart now go to your memory enjoy''
Punteggio 1
1 Commento:
What do mean by "open cfw"? Are you saying the recovery mode?
da
Try downloading a custom firmware, there you can recover the games when starting up your psp.
Punteggio 0
1 Commento:
Where i can find the cfw?
da
I had the same problem i fixed it only watching this video
https://youtu.be/CayL-S7w2e4
Punteggio 0
Hello everyone
I have a different problems for my psp
Right before i connect my psp to my laptop, i can see all the games from my psp and play it normally for hours. But when i want to copy another game from my laptop then disconnect the psp, there are no games left when i open the psp again. To be honest, the game and all the content is still there when i open it through my laptop. The only thing that i feel strange that the psp usually show me all the folders at once, now it dissapear and hiding inside 1 shortcut where when i open, it lead me to where all the folders are hiding but not losing any contents. Can anyone help me please? Thank you
Punteggio 0
1 Commento:
i have the same problem
da
Hello everyone
I had the same problem i fixed it only watching this video ^_^
https://www.youtube.com/watch?v=OoivsH5T...
hope it will works for you ^_^
Punteggio 0
Hello All,
I've not connected my PSP to any system but my games are corrupted.
Please i need assistance.
Thanks
Prince Felix.
Punteggio 0
When you connect your psp to your laptop. The games auto hide .you have do these steps.
1.copy all the files in memory stick to your laptop.
2. Format the memory stick on laptop (2 times).
3. Put the memory stick in to the psp and format from the psp (2 times).
4.then connect your memory stick to your laptop via a memory stick adapter.
5. Paste games that you copy into iso file . Then you can see the games . If it doesn’t work you have to download pro update.
Thank you!
Punteggio 0
Trying to repair my PS3/00
Punteggio 0
Hi guys if you a problem like this this is how you resolve this so you want to update youre psp you go to the download page of the psp updates and you put the EBOOT.PBP file in GAMES and youre say where is my file
the step that you are doing is wrong brcause you have to put the EBOOT.PBP file into a folder called update and youre games should be in a folder to because PSP is arange
Punteggio 0
if you have any type of umd isos in your iso file u have remove them
to add umd isos in the psp u gotta make a video file in the iso file
Punteggio 0
Aggiungi la tua risposta
ahmer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 65
Ultimi 30 Giorni: 239
Tutti i Tempi: 81,809
