Salta al contenuto principale
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
70 Domande Visualizza tutte
Will the fan replacement method be the same with the Inspiron 1520?
There is only a guide to replace the Inspiron 1525 CPU fan. I have a Dell Inspiron 1520. Will the replacement method be the same for the 1520?
Thanks!
Ray
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Ray, not sure if it is the same as it is for the 1525, but you can download the service manual for your model from here ftp://ftp.dell.com/Manuals/all-products/... Page 31 will show you how to change the fan. Hope this helps, good luck.
Punteggio 2
1 Commento:
I'll keep that link :)
da
Hi,
As both laptop belongs to same family you can do that however detaching a fan in a laptop is a patience needed job a little mistake can cause a CPU damage i would suggest you to take your laptop to a technician and have him do it for you.
Good Luck.
Punteggio 0
Aggiungi la tua risposta
Ray sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 589
