Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2376 Domande Visualizza tutte
problems with the lock button and power cable even after replacement.
I was looking at a phone that was having issues with the lock button sticking and not working. I have fixed this before on other phones with no problem (solutions from here that I have tried with success: unscrewing the bracket just a bit, taking the button out and making sure it's aligned correctly, replacing the button, replacing the cable). This has always been something I have had very few problems fixing. The old cable on this phone was missing the little plastic bit that helps push the contact point down and wasn't "springy" when i pushed it without the button on top so I replaced the cable. No matter which button I used, old or new (which really shouldn't make a difference they're all the same pieces of little metal but I have seen that suggestion on here before), it still wouldn't press down or even register at all. IF anyone has any ideas or solutions that would be amazing,
Thank you
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
3 Risposte
Try undoing the screws a tiny bit some times when there to tight the button won't register.
Punteggio 0
1 Commento:
I have tried this solution as well and it didn't seem to help, any other quick fix ideas? :)
da
I have almost the same problem after replacing my ribbon for the button. However, the button will now press and click just fine, but it doesn't register with the phone at all.
I took it apart to check the cable, and when I put it back together the LCD no longer works.
Punteggio 0
Have you the metal button in correctly the spring should b on the bottom of it when it's in place
Punteggio 0
Aggiungi la tua risposta
Cleo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 149
