Salta al contenuto principale
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
power button will not put ipad to sleep
I've got an iPad that I'm fixing the screen on. I've got something bizarre going on that the power button won't put it in or take it out of sleep mode. However, it will power the iPad down. I'm pretty sure I didn't rip the power flex cable. Been down that road before. Any ideas?
Questa è una buona domanda?
Punteggio 1
1 Commento
I was able to resolve the issue by turning off the setting for the smart cover. After that it worked like it should.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Try turning the Smart Cover settings off. If the issue disappeared, then the magnetic sensor is damaged. You can also try the compass, which should also be dead.
If the problem is not caused by the sensor, try restoring the device
Punteggio 1
Aggiungi la tua risposta
Ethan Grier sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,178
