I have just had this exact problem and lots of googling searching brought me to this unresolved post which i thought should get some closure.
I had this issue, and no amount of OS repair, factory resetting, wiping, using JL_Commander, BBSAK or BBDM features would recover my Torch 9860 until I came across this thread;
http://forum.gsmhosting.com/vbb/f489/nuk...
I believe the difference with this all in one script is the small exe that actually formats the device sector by sector - it even wipes any stored pins from the device - thoroughly cleaning the ram out rather than just deleting apps and re-stamping the OS.
I used options 2,3,4 and 6 as I could not lcoate the nal.exe file for the 9860, and after using this program, I then re-installed my OS to the phone using the loader.exe, but I am sure at this point, the BBDM repair options would have worked aswell. You probably only need options 2,3 and 4 really as the OS load can be done with loader.exe or BBDM
After a succesful rebuild, the phone takes a long time to boot (about 10 minutes - no joke) but it does eventually boot (you do see the white bar move V E R Y S L O W L Y after where it normally gets stuck)
Hope it helps some others out with the same issue.
Jason
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
8 Commenti
I've read a lot of negative reviews with these phone, and I've got this since last month and now I'm experiencing the same issue - I was disappointed since I'm really looking forward to have a touchscreen BB phone. I used 9320 for almost a year and I never had an issue with this. First it took me more than 24 hrs to use the phone when this issue happened, but now it is not working. Totally a waste of money I'm working in a telco company but it seems that I was too excited to have the trial version of BB with touchscreen phone. And yet these hasn't been resolved and all I see is referring them to BB tech support...
da darwinpido
my phone has the same problem, please guys we need solutions now
da foxheal
hi am having the same problem as everybody what should i do???????????????????
da amandabarratt76
me toooo , a great disappointment
da wasim
the phone is giving me a hard time i have tried flashing it with the software i think should work but nothing is coming up, should i just flush it down the toilet?
da bayode
Mostra altri 3 commenti
