Salta al contenuto principale
THINKPAD T520: Top Tier Performance and Portability.
17 Domande Visualizza tutte
Domanda Chiusa
Why does my laptop keep on beeping at me?
A few months after i got my laptop something weird was starting. Everytime I kept on trying to turn on my laptop it kept on beeping three times at me. It also stops the screen from turning on, can someone please help me, I need to fix it!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta Più Utile
Katie Louise, you should tell us more about the exact beeps.One long and two short beeps, and a blank or unreadable LCD are indicative of either a bad mother board, a bad LCD, or bad memory modules. I would start by attaching an external monitor and see if it makes a difference. After that, pull the memory modules and reinsert one module at a time. Make sure that it is properly seated. If none of this works, you probably have a bad mother board. Hoe this helps, good luck.
Punteggio 1
2 Commenti:
The first beep is long, and then nothing happens for 2seconds than the other two go one after the other. I have a bad mother board, i tried all your steps but none of them worked :( thanks for trying to help anyway :)
da
Thank you for accepting my answer. sorry to hear about your motherboard. May be you could still be covered under warranty?
da
Questa risposta era destinata originariamente a un'altra domanda.
3 BEEPS -- PAUSE 3 BEEPS ETC... USUALLY EQUALS MEMORY UNSEATED OR MISSING. Reseat the memory in it's sockets
Punteggio 0
My computer is beeping. There is usually 4 quick beats, then over 10 slow beats, then just random. What could the problem be?
Punteggio 0
2 Commenti:
sonya what make and model is your computer?
da
Hi, it is an Acer aspire 5732Z
da
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 7
Tutti i Tempi: 5,375
