lost my password(LOCKED OUT OF THE SYSTEM)
I'm locked out of my system, i kinda forgot my password and i'm locked out and i have work to do.... please...
COMPAQ PRESARIO CQ56 WINDOWS 7 STARTER...
Questa è una buona domanda?
You might have to reinstall you OS (windows 7) to get access. Try booting a Linux OS and transfer out files you need. and then format and reinstall.
Anyone have a second opinion on this issue?
I don't have any other opinion
I have no idea to restore the password for a Windows computer ,it is hard to do that,but you can remove it and make a new password as a login password.
So let's do that: https://www.mobiledic.com/windows-topic/...
You don't need to reinstall the Windows 7 OS. You can create a password reset disk to reset the password. Here's the tutorial.
What if I have window 10 pro on CD and want to install it but cant cause no password
If I don't have the password I can't get into the computer to burn a disk... think about it for a second.
you can try to remove it with a software call heinz boot cd or something like that.It won't delete any of your data and it will remove/change your password.*Careful when using that.
I'm lock out of my laptop predation cq60 compaq
I'm lock out my laptop
Hi, you can try one of the following ways to reset your lost Windows 7 password:
Way 1: Re-install your Windows 7 system
This is the last choice that you really don’t want to try. We list it here because it’s a certain fix for a lost HP password problem. A clean install of Windows will erase your hard drive and time consuming.
Way 2: Reset Password with HP Password Reset Disk
Windows 7 features a built-in function letting you to create a free HP password recovery disk. However, you should create it before you lost your password.
If you have locked your HP computer with a wrong password, you'll receive a message that says your user name or password is incorrect. When this message appears, click “OK”. Click “Reset password”
Way 3: Have another Windows 7 Administrator Account to Reset Your HP password
If you have multiple user accounts and at least one of those has administrator privilege. You can reset standard user account password.
Way 4: Use Windows Password Key to Crack HP Password on Windows 7
It seems that every method above is not so perfect. Is there an ultimate way to reset lost Windows password for HP computer? Definitely yes. Windows Password Key is especially designed to help HP computer users reset forgotten password for administrator and other user accounts.
Step 1: Download and install Windows Password Key on any available computer.
Step 2: Insert a boot-able CD/DVD or a USB flash drive on the computer. In the pop-up window, select “Reset Windows local account password”, choose your CD/DVD or USB flash drive, and click “Burn”.
Step 3: Start you PC and insert the newly created CD/DVD or USB flash dive on the PC.
Step 4: After Windows Password Key initializing, choose the Windows installation, select administrator account, enter a password, click “Reset” and “OK” in the pop-up windows and click “Reboot”.
If you are confused about using Windows Password Key don't hesitate to visit the following website: http://www.lostwindowspassword.com
I lost my password to my Compaq
Labtop and need help receiving it. Thank You
Cant reset password dont have a usb cabel wont let me reset
normaly you can recover this whit a recover this with a recovery disc, you can make that. Also, (dont know for sure) cant you edit it while in safe mode?
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 31
Tutti i Tempi: 56,045
5 Commenti
Locked out of your system or your OS? Do you need to enter a password to even get it to load Windows? If so, a reinstall of your OS will not work.
da oldturkey03
Linux can hack computer passwords, if you can boot from CD and have another PC spare I can help.
da Jonny Barron
It don't works for my Windows 7, 64. as for me, I used the iSeePassword Windows password recovery standard version to reset my login password , it's very easy to use and safe! You can see how it works.
da Misnilaliy
https://pogostick.net/~pnh/ntpasswd
da Robert
I remember i used wingeeker to bypass my win 7 login password, it's easy to use , but you need to make a reset disk with a USB or DVD.
see this: https://www.tunesbro.com/reset-windows-7...
da pall iris
