Salta al contenuto principale
Repair guides and troubleshooting for HP Pavilion dv7 laptops, manufactured by Hewlett-Packard starting in 2008, and featuring a 17.3" diagonal display.
How can I replace the flex?
The computers boots up. However, the screen turns on and off rapidly or doesn't turn on at all. The problem is independent of the position of the screen.
EDIT: Using a flashlight I realised that you can barely se the screen. So the problem is the backlight.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
simon, exactly what flex are you trying to replace? the reason for not having a backlight could be a bad inverter, a bad LCD, a bad Lid swithc or even a failed backlight circuit (common failure on this model) it is under the right side hinge. "However, the screen turns on and off rapidly or doesn't turn on at all" sounds more like a broken backlight cable or a failing switch.
Punteggio 1
Risposta Più Utile
From what you are describing it is possible the flex cable is damaged as it carries power to the inverter for the back-light however it could also be a faulty inverter board.
The cable and inverter can be purchased for around $30 so perhaps just replacing both may be the best approach.
Inverter replacement video
Punteggio 1
Aggiungi la tua risposta
simon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 3,354
