Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
Phone dropped-display now flickering
Last week I replaced the battery using your guide. Yesterday my wife dropped her phone (in a LifeBox case). The phone would not turn on or reboot. I opened the phone and found that the battery had shifted. I repositioned it and now the phone boots and works but the display is flickering. I tried changing wallpaper but no help.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Do a hard reset hold and press power and home button at the same time til you see the apple logo.. If that doesn't work then you have damaged the LCD to fix the flickering you will need a replacement
Punteggio 1
I am going to put my money on the LCD having a broken connection somewhere. Flickering means it is getting an intermittent connection. Just my $.02.
Good Luck!
Punteggio 1
Aggiungi la tua risposta
dbechler51 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 12,294
