Salta al contenuto principale
Modello A1312 / metà 2011 / Processore Core i5 da 2,7 e 3,1 GHz o Core i7 da 3,4 GHz, ID iMac12,2
708 Domande Visualizza tutte
memory RAM reuse recycle upgrade
I have several 1GB & 2GB RAM chips some are OEM 2gb from my imac and Macbook Pro that are still good can iFixit use them??? I cannot use them anymore and I do not want to throw them out! I upgraded the OEM are out of a 2009 27íMac i7 and 4 - 2GB are out of a 2011 27"i7 Imac
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The EMC 2429 i5 uses PC3-10600 DDR3 Min. RAM Speed: 1333 MHz
Details: Supports 1333 MHz PC3-10600 DDR3 SO-DIMMs (204-pin).
Slower RAM will not work.
Punteggio 1
1 Commento:
Please do not change the original question, just add a comment to clarify.
The 2009 i7 Supports 1066 MHz PC3-8500 DDR3 SO-DIMMs (204-pin)
The 2011 i7 Supports 1333 MHz PC3-10600 DDR3 SO-DIMMs (204-pin) and will work for you.
da
Aggiungi la tua risposta
Krisy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 218
