Salta al contenuto principale
Model No. A1367 / 8, 16, 32, or 64 GB capacity
20 Domande Visualizza tutte
Restoring iPod that is disabled and also has a broken power button!
I'm in the possession of an iPod 4th Gen that has a broken power button and is completely passcode disabled.
Is there any possible way to restore it?
You can not use itunes as it will complain about the passcode and I cant manually put it in DFU mode as the power button is broken.
Programs such as Tiny Umbrella and Rec Boot will not recognise the device since it is passcode disabled?
Help... lol
Questa è una buona domanda?
Punteggio 13
2 Commenti
I need a way to reset my ipod I am disabled my home botton does not work
da
how to restore softwear without home button
da
Aggiungi un commento
6 Risposte
Soluzione Prescelta
Here you go mate
http://www.greenpois0n.us/2011/08/downlo...
Punteggio 3
4 Commenti:
Great answer. I would upvote, but apparently there is a 50 per day limit.
da
That makes no sence jack :/
da
I just read into why Recboot was not working for me. Apparently it does not work correctly on x64 versions of Windows :/
da
Not if you can't solder tho
da
If RecBoot does not work, you need to replace the power button.
Punteggio 2
1 Commento:
Thought that may be the case
da
Repairing the button will always be the straightforward solution
Punteggio 1
Hi Folks,
after struggling for 2hrs, I finally found the solution!
I had bought a disabled ipod G2 on an auction site... It looked impossible to unlock it! I couldn't go into the DFU after trying at least a hundred times (eventually, I found out that the home button is lazy...)!
Anyway, after re-reading the same procedure over and over, and working for a device manufacturer myself I was pretty sure there existed a SW only solution to do that (I can't imagine that people in the production need a roughly 30 sec procedure to flash a FW).
I eventually found it! it is called RecBoot. There are 2 versions, 1.3 seems to be the latest for Win7 32bits (the one I used) and there is another one for Mac which is already at v2.2. I loved those guys who made it! it took me about 30minutes to get my ipod working (I needed to reinstall itune)! (just load Recboot, choose the mode and plug the iphone/ipod in)!
Just google it and download it (about 700k).
Punteggio 1
3 Commenti:
thx!!!its working
da
does this really work
da
awesome, u save my live dude,, thank you very much
da
recboot is awesome. thank you very much guys
Punteggio 0
If Recboot doesn't work, try to use Tenorshare Reiboot
Punteggio 0
Aggiungi la tua risposta
Tim Carruthers sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 62,692
