Salta al contenuto principale
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
How do you repair or replace ethernet port?
I have a first generation PS3 and there is no internet connection upon connecting an ethernet straight from my router. I have tried all troubleshooting of it being a router/internet issue. I believe the ethernet connector itself is loose or broken. I need a guide on how to replace the port. I tried local shops and they don't know how to fix it.
Questa è una buona domanda?
Punteggio 3
2 Commenti:
Very first question I would ask you, is if you have soldered on a logic board before? I had a difficult time with the USB port re-soldering. I found that the solder used by the manufacturer seemed to be difficult to melt. You will need a good soldering iron/station and some good skills to get this done.
da
If I have a guide I can do anything. I have soldered audio equipment before amps and subwoofer wiring etc.
da
Aggiungi un commento
1 Risposta
You need to dismantle it to the logic board, then use a desoldering braid to remove the soldered connections of the ethernet jack, then put a new one in.
Punteggio 0
Aggiungi la tua risposta
Jacob sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 3,610
