Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
mute/silent switch not working after changing audio flex cable
Hi guys,
I have successfully repaired the power button with replacing the audio flex cable. BUT the mute switch isn't working anymore!!!... What can I do? De assemble and re assemble? Or could it be a faulty part (or damaged by me..)
Any advice please..
Thanks
Questa è una buona domanda?
Punteggio 0
1 Commento
bump bump bumppppp
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
could be a faulty part. replace with the old one and check if it works
Punteggio 0
Do not know where you purchased your part ...
Dismantling and assembly will not help you ....
Or maybe during the correction hurt in flat cable
Attempt to replace a new one, this time will be more careful :)
מעבדה לתיקון גלקסי
Punteggio 0
I realize this was answered years ago, but I just had the same issue and the solution was simple and stupid. The mute button's bracket has a tiny little nub of a switch, and the button itself has a slot -- they both need to be either up or down. Like I said, simple and stupid.
Punteggio 0
Aggiungi la tua risposta
Mike sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,038
