Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
iPhone 4S wifi greyed out/ no signal after button replacement
Hello
My iPhone had a broken Power button, which I replaced.
But after I opened the iPhone and fixed the button, the iPhone shows most of the time a greyed out wifi and it keeps showing "Searching" and it does not recognize the SIM card.
Now I replaced the wifi antenna but this didn't fix it.
The problem must be on the logicboard.
How can I try to fix it (reflow etc?)
Which part of the logicboard is faulty?
Thanks in advance for your help.
Questa è una buona domanda?
Punteggio -1
3 Commenti:
Nobody an idea?
da
was it working fine before the power button replacement ?
da
Yes was perfect before
da
Aggiungi un commento
1 Risposta
Does the device pick up a phone signal? If not, your problem could be related to your baseband. It controls your WiFi, Bluetooth and phone signal. What baseband are you on? Check by going to Settings>General>About>Modem Firmware.
For more information: How to fix WiFi grayed out in iPhone 4S
Punteggio 0
Aggiungi la tua risposta
Fuad sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,893
