Salta al contenuto principale
First-generation Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
71 Domande Visualizza tutte
Are the ipad 1 and ipad 2 lcd panels interchangeable?
Question as above. I have an iPad 1 with the grey band issue, and I was wondering if an iPad 2 lcd will work. I know they are the same resolution, but is there any cable length difference between them?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
No.
The iPad LCD is attached to the Digitizer with 5 T5 Torx Screws.
The iPad 2 LCD is attached to the rear housing with 4 Phillips Screws.
Punteggio 0
NO. They are NOT compatible.
Punteggio 0
Aggiungi la tua risposta
Paul Masterson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 18
Tutti i Tempi: 2,183
