Salta al contenuto principale
SanDisk Ultra Plus 256GB 2.5 SATA III SSD fit
My PB G4 is overheating and I want to replace the hard drive with the SanDisk Ultra Plus 256GB 2.5" SATA III SSD. It seems like a relatively complex procedure and I am not sure I am up to it. Finally, I do not know if the SSD will fit in the PB G4.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Not a good idea your machine can't use SATA drives it's' UltraATA, so you'd have to find and fit a gender-bender (not even sure such a thing exists) if it did, the drive may have problems writing that slow, causing freezing and hanging.
If this Answer is helpful please remember to return and mark it Accepted.
Punteggio 1
1 Commento:
Great advice and wonderful contributor! Thanks!
da
Accepted with thanks!
Punteggio 0
Aggiungi la tua risposta
Dave Dorn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 466
