Salta al contenuto principale
Desktops manufactured by Sony.
open the Sony Vaio VGC-JS to expand the hard disk
Sony VGC-JS All-in-One Model PCG-2P1M, hard disk failure
All-in-one PC solved all the screws, will not open.
How can I get the hard drive?
Urgently need help. Thank you!
Thanks for the drawing.
I can not release the stand. Is there a trick?
Questa è una buona domanda?
Punteggio 0
1 Commento
http://www.youtube.com/watch?v=Hl0QI69xn...
This is the solution!
All screws on the back and bottom. Then solve the edge gently with a small object.
Thanks for the video!
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Mirjam Graf, this is a bit of a beast to open. Check the attached image, all the parts that need to be removed are highlighted. Here is a okay video that might be helpful to you too.
Hope this helps, good luck.
Punteggio 2
1 Commento:
I need more help, thank´s...
da
Aggiungi la tua risposta
Mirjam Graf sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 3,785
