Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2201 Domande Visualizza tutte
Screen not working properly after replacing proximity sensor
Hi everyone
I replaced the proximity sensor cable as my power button was not responding , I accidentally misplaced the sensitive bracket that was on the initial cable,( it's a little square plastic bracket) wish I was supposed to remove from the old cable and put on the new cable ,couldn't find it on the market so I reassembled the phone without it anyway,
Now my screen is not responding as it should , I press on one thing and it opens the option or app next to it.
Here is my question , does it have to do with this missing bracket ??
The lock button works fine , when I try to make phone call and cover the sensor with my hand the screen goes dark so works fine .
Thank you
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You don't need that clip I would try a hard reset hold power and the home button at the same time til the phone shuts down and you see the apple logo hope it helps.
Punteggio 0
Aggiungi la tua risposta
Elias sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 201
