after changing the cpu and HDD the mac mini doesnt work!
i made all the steps for change the cpu from core duo to core 2 duo. I made all the steps correctly, switching and connecting everything again but when i turn on the mini again only the power led works. I tried to insert a cd to test if the dvd reader was working but nothing happened. I can suppose there is a problem in any part who connects the motherboard, but dont know exactly. please help!!!
Questa è una buona domanda?
4 Commenti
i connected again the old Cpu, but happens the same. I'll try again with the old HDD , but this doesn`t look well....
da tito
Did you use proper ESD protection? You may have zapped the logic board or CPU/s
da Dan
yeah, i did it before the surgery. Thinking about that, when i took the alu. heat sink it was glued to the cpu by the termal paste. I tried to remove the sink softly but finally when i pulled it , it came with the cpu. So i removed the cpu with socket lock on. At first sight everything was still well , the new cpu was inserted well again on the socket but the damage was done, i think.
BTW, the new cpu is a p8400 2.2 GHz core 2 duo. Looks exactly like the old (t2300 1.6 ghz core duo). will it work? or only T series processor???
Anyway thanks for your time!!!
da tito
The one thing the guides don't tell you is how to pull the heat sinks off. Sometimes they come off easily, other times you encounter what you did. What I do is twist it off (shear Vs lift). Think how two pieces of glass can stick together to the point you can't pull them apart but with a twist they can be.
da Dan
