Salta al contenuto principale
Informazioni di supporto e riparazione per i notebook realizzati da Samsung.
Blue Screen of Death?
When I import photo's from my I-phone I get the BSOD
Questa è una buona domanda?
Punteggio 0
1 Commento
What is the Windows version do you have and iTunes. If you are directly accessing the files from your iPhone when does it blue screen on you? After you have plugged it in or as you are coping the files.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
This problem occurs when the windows come across a problem from which it can not recover. To get rid of BSOD problem you can do these things:
1. Press F 8 key and get in safe mode
2. When starting the laptop in the safe mode scan your entire system for the virus and malware problem if it exists eliminates it.
3.If you have recently installed a hardware then re install the drivers for it or uninstall the hardware itself.
4.Registry corruption is also a reason to overcome this problem use a good registry cleaner.
Hope your problem will get solved. Good luck dear.
Punteggio 0
Risposta Più Utile
Shut down the whole computer . Then start the computer again and you will go to the sign in page , look at the right bottom power button in your page and choose restart then is fixed !!
Punteggio 1
Aggiungi la tua risposta
Patrick Sticka sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 63
Ultimi 7 Giorni: 124
Ultimi 30 Giorni: 1,206
Tutti i Tempi: 7,578
