Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
Why is my iPhone directly overheated
Hello,
I got myself an iphone.
But now, when the iphone turns on the iphone says its overheated but i havent even turn it on before.
So it must be cooldown.
If i try to google something like this their wont be any answer so please if some one can help me!
Would be great
regards,
Questa è una buona domanda?
Punteggio -1
1 Commento:
hello daniel,
as soon as i connect to itunes my device disconnects dhe the overheated message. i have ordered a new battery so i hope it will be here asap.
hope to gere from you about the disconnecting problem
da
Aggiungi un commento
3 Risposte
Hi there
there's only a few things that will cause your phone to overheat
1) hardware problem
2) iOs problem
3) lots of apps running and high memory usage
since 3 obviously isn't your problem, i would suggest a factory wipe, and fresh install of iOs.
if that doesn't solve it, the only other thing is the battery itself.
hope this helps :)
Update
not quite sure I understand. are you saying when the message is on the screen and you plug it into computer, the message disappears? out of curiosity, where are you getting the battery?
Punteggio 0
Restore the phone, if it didn't work, then the Themal sensor is shorted, it's a hardware issue
Punteggio 0
What a stupid solution: wipe out everything and start over. Dumbest thing I have ever heard. Pitiful...get an Android...
Punteggio 0
Aggiungi la tua risposta
Desley sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,644
