Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Domanda Chiusa
iPhone stuck on edge
I having a weird problem with the iPhone 5. When I am in a building where the reception is poor, the device picks up edge network signals. But when I leave the building and move to an area where I know there are strong 4g signals, the device still clings to the edge network. The only solution is to go to airplane mode and back or reboot. Does this sound like a software issue or a hardware issue? ATT has replaced the sim and reprovisioned the account and Apple has replaced the device once. It's still not fixed.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Cellular handovers are not so active as you would think. Frequent scan/handing over impacts battery life. If you still wish to give it a push, cycle airplane mode, as you already are doing
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,857
