Salta al contenuto principale
Guide di riparazione per i telefoni android prodotti da Motorola (una sussidiaria di Lenovo), inclusi cellulari, smartphone e la popolare linea di prodotti Droid.
2409 Domande Visualizza tutte
Fixing water damaged Accelerometer and Gyroscope?
Hello. I dropped my Motorola RAZR HD on a swimming pool and it went down around 30-50cm for around 3 seconds before it was taken out. When I took it out everything seemed to work fine (it powered on fine, had signal, was receiving calls, sms, etc) except for the touchscreen, so I couldn't unlock it.
I took it to my carrier and they sent it to Motorola were they said that the damage was not reparable and the phone was not useful anymore.
But when I turned it on it was just working out perfectly, even the touchscreen was now working. Everything like nothing ever happened.
Except I realized the Accelerometer and Gyroscope were not responding at all. I downloaded AndroSensor and Accelerometer Monitor (apps) and there was no response at all. I can't play some games, I can't watch videos on landscape, etc. :(
It is certain that it is a hardware issue from the water. I want to know if there is a way to fix it. Do I have to replace it/them? How easy is it to fix/replace? How much would it cost?
Thank you very much in advance.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Both of those are IC components on the logic board. The only feasible fix would be to replace the logic board. After a drop in the pool, I'd expect far more damage.
Punteggio 0
2 Commenti:
Yeah, I feel lucky these components were the only ones that were damaged. How hard/costly is it to replace the logic board?
da
What's your model #?
da
Does anyone know if the gyroscope can dry out and function over time?
Punteggio 0
Aggiungi la tua risposta
Mauricio Berlanga sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,459
